Has anyone had their oil light flicker at idle ? I made a few passes on my 06 and it started flickering at idle but went away with rpm. So I let the bike sit and cool off a little bit and it seems fine now. Oh and yes it shows to have oil in the sight glass.
(ozz @ Mar. 23 2007,22:25) as the busa gets hotter it tends to idle slower just bump up the idle to around 1150rpms while the motors hot and the oil light will stop
I have a similar problem, but my oil light does not go out with increased RPM's. Just changed the stator and filled up oil two days ago. Everything appears to run as advertised, but oil light intermittently flickers randomly. Any ideas?
