Hey all,
I have been thinking of going with a electric shifter,
http://www.pingelonline.com/eshifter_suzuki_gsxr.htm
I wanted to know if anyone knows anything about this. As you can tell I like toys, So this isn’t just for the track. I wanted to hook it up to a RPM window switch so that at the high set point it up shifts then at the low set point it would down shift. This window switch circuit would be controlled by a handle bar mounted switch, so that I can turn it off when I feel like shifting the old fashion way. With this turned on I want the bike to act like an automatic Busa! Any and all input is greatly appreciated, even bad!
