If you go out there and use common sense you'll be fine. Roll into the tree slow. when the first light comes on slowly inch forward until the second light comes on. Just do a normal street launch. Or even about 4,00 rpms will give you a solid launch. I launch my 750 of the limiter and ride the clutch a little. But I'm sure it will be different on the busa. All the guys I race with use shinko 190 rearsat 35psi and launch at about 6,000. they all run in the low 10.00s high 9.90s.
