free cruise control.....
crank yer Choke(not really a choke,more of a throttle speed adjust.) up to the max...ie , tighten the cable,make some adjustments....
or....25 cent O-ring , keep it on the end of yer throttle grip,when you want cruise control roll it off the grip into the space between grip and bar-end....actually works...
or...I could shut the fug up , and you could go buy some expensive thing....
I use a throttle boss on long hauls.....
Have a good 1....RSD.
