Swap the fluid and fan. Your fan will still kick on in traffic but wont stay on as long.
I know it's been talked about before, but I'm a little concerned.
On Friday when I first got the chance to ride the busa in Hollywood, the fan came on but the needle didn't get past the 1/2 line (maybe just a little bit). I guess it's because all the stop n' go traffic and not being about to really get it up to speed for very long with all the stoplights.
Tonight I went for a ride around Hollywood and Beverly Hills because I was bored and the bike's fan still came on even though I wasn't in any kind of traffic jam. Is it just because I'm having to keep the bike in lower gears and stopping at so many stoplights? I'm just concerned and wanting to know if this is normal/expected...
Thanks.
Here's a pic, because I know we all like them.
Rodeo Drive around midnight.
2006 blk/gry (custom decals/paint)
akrapovic b/o exhaust
carbon fiber mirrors
carbon fiber inners
puig dk smoke db
suzuki chrome tank pad & tre under it!
hotbodies undertail (lights suck!)
vortex 43 sprocket
dunlop qualifiers on the streets...
shoei rf1000 picotte III on my head. Period.
"Getting into a beef with the military about the war is to me like getting into an argument with a cop about the law; it's really not the person to take your grievances out on."
Henery Rollins
fan a +
long as it does not go past 1/2 way. mine rides right at the 1/2 mark no higher
i constantlyat mine. but its like a car . a car rides right in the middle also,and no problems. but we all seam to worry about our bikes that do the same thing.
hay pan glad to se ya make it of to cal.![]()
no mods only ideas
Nice picture and welcome back!
echo ${flames} ${comments} ${ridicule} > /dev/null
<div>
(unkleslapnutz @ Nov. 06 2006,04:42)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Swap the fluid and fan. Your fan will still kick on in traffic but wont stay on as long.</div>
swap to what
Name the fan. Name the proper fluid. Thanks, bro!
carbon fiber inners
puig dk smoke db
vortex 43 sprocket
I just "feel" like I'm overheating, here! The bike just does NOT seem normal like it did back in AL. That's all....
carbon fiber inners
puig dk smoke db
vortex 43 sprocket
OH... thanks to those who rated my butt above Paris Hilton.... hehe!!!
carbon fiber inners
puig dk smoke db
vortex 43 sprocket
It's that crazy California gas......
Way different form our NorthEastern Blend.
oh.
carbon fiber inners
puig dk smoke db
vortex 43 sprocket
Fan = Muzzy
CLICK
Coolant = Engine Ice or Water Wetter. I have Water Wetter in mine and haven't had any problems at all. My needle goes no higher than BARELY over the halfway mark, even when I'm stuck in traffic in 90+ degree temps. I heard Engine Ice is the absolute best thing to use but since Water Wetter was cheaper and Engine Ice was harder to find, I decided to try it out W.W. first.
Muzzy Fan
<img src=http://www.muzzys.com/catalog/cat_photos/fan.jpg>
Engine Ice (No mixing needed)
<img src=http://www.holeshot.com/chemicals/images/engineice.jpg>
Water Wetter (Mix with H2O)
<img src=http://www.horsepowerfreaks.com/Images/Products/Redline/Radiator_Fluids_Water_Wetter.jpg>
You can try some water wetter or engine ice to try to get the bike to run a little cooler if it's really bothering you. Changing the fan won't make the bike run any cooler, only pull through more air to cool it down after it reaches the temp that kicks the fan on.
The Kings pain is your gain
"Far better is it to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who neither enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat"
Teddy R.
below highway speeds the fan will tend to come on even in cooler temps. air flow to the radiator to cool this engine needs to be higher as this is a larger engine and produces alot of heat. don't worry about it unless the temp needle goes to the 3/4 or higher, side of the gauge, and definately worry if the light comes on. if your really worried about temps your could install an actual temp gauge to read actual coolant temps, but on a near stock bike I would think that this would be overkill.
11 Ducati Diavel Carbon (black)
10 Motorsport BMW S1KRR
09 Pearl White Ducati 1198
your bikes working properly, enjoy![]()
Bill
Now,make sure the rope is tight! It's got to hold the weight of a pig! ELI WALLACH as TUCO.
The Good, the Bad and the Ugly
Finally thanks Mr Anderson. The fan is suposed to run thats what its there for.
anyone have any reports on the fan switch relocater from 1300cycles?
pan moved to caly i`m moveing to arizona.
no mods only ideas
It turns the fan on sooner
GenMar 1.25” Front, Adj. Links Rear, Pazzo Levers
Puig DB, Bad Boy Sliders, Grill Screens
Akrapovic Evolution w/Carbon, Tobin Seats, Muzzy Fan
PCIII usb, BMC Race Filter, GIpro, Scorpio Alarm
EBC Contour Light Front Rotors
EBC HH Front & Rear Brake Pads
Dymag CF Wheels
