Hey KS what is the keeper thing 6mm bolt ??Don't forget the keeper 6mm on the front sprocket....... This is an average do it yourself project! Take your time and everything will come out fine.
do you really need a torque wrench to do this?pretty easy mod really and cheap too. ive done it with the last 3 bikes and never had a rear stand or any kind of chain failure. just adjust the slack and use a torque wrench.
I'd say so. I'd think it would be fairly critical that you get the sprocket tightened to spec. Some other fasteners might not be as critical but anything in the driveline or suspension should be torqued to specs, IMHO.do you really need a torque wrench to do this?pretty easy mod really and cheap too. ive done it with the last 3 bikes and never had a rear stand or any kind of chain failure. just adjust the slack and use a torque wrench.
agreed, especially axel nuts.I'd say so. I'd think it would be fairly critical that you get the sprocket tightened to spec. Some other fasteners might not be as critical but anything in the driveline or suspension should be torqued to specs, IMHO.do you really need a torque wrench to do this?pretty easy mod really and cheap too. ive done it with the last 3 bikes and never had a rear stand or any kind of chain failure. just adjust the slack and use a torque wrench.
