| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
Its little rubber pieces in between the rear sproket mount and the rear rim. Acts as a cushion when you nail the trottle to save on some of the wear and tear of other parts.
______________________________________
" WHY DO NEW THINGS GET OLD FAST AND OLD THINGS GET BETTER WITH AGE?" "I've got one life to live.....lets get it over with!" "At 186mph I am not ignoring fear, it just hasn't caught up yet." "You may love it or you may hate it but you can't ignore it." |
^ yea...what he said. It is inside the center of your rear wheel.
'05 BLACK & SILVER. Speedohealer Hump mod Kickstand mod Acumen gear indicator Pazzo shorties Woodcraft stator cover Brendans seat pins Brendans tank pins |
Thanks! So how do you tell when one needs to be replaced?
Shibumi- Effortless perfection. That describes the Hayabusa! 03 Black/Silver- Akasha Power Commander/BMC Race/TRE/Muzzys/Lowered/Galfer stainless lines/Pingels/Puig Double Bubble smoked/Shovel mod/Pazzo shorties/HID/CA clear taillight w/integrated LED signals/Clear front signals/Qualifiers |
<div> (Shibumi @ Sep. 18 2006,16 I knew mine was gone because you could feel a clunk when you nailed the throttle, kind of like having a bad U-joint on a car, also if you remove the rear wheel to replace a tire and the sprocket and hub falls out onto your bare feet from about three feet up,teeth first OUCH!!! you know their worn, that's how I found out what *cush drives were in the first place. I guess you could also grab your rear sprocket (with the rear wheel installed on the bike) and try to rock it back and fourth, see how much slop you have from the sprocket and the wheel , youll have a little movement, but it's pretty obvious when it's shot, if yours was shot, you would have been placing a post on here asking, whats that noise when I nail the throttle |
Cool. Thanks for the info, guys! Brianm, OUCH! See, never even WORK on your bike without gear on! ______________________________________
| Thread Tools | |
| Display Modes | |
