Which year?
1999/2000 are unrestricted. 2001, just use a 5th gear TRE or 6.8K resistor on the gear position sensor. 2002, no de-restriction methods as of yet.
What do I need to do to remove the neccessary items so a Hayabusa can go as fast as I want without any after effects related to the engine.
Which year?
What year?
You can not remove the speed limiter, you can only go around it with a TRE or similar.
Narcissus,
Talk about typing at the same time. Your anser was better anyway.
