hey guys! my clutch master cylinder oil was so dark i had to drain it empty to clean carefully the interior of the reservoir my problem is that i cant seem to build pressure.ive bled brakes before and never had this problem any ideas im stuck |
the system was drained by gravity and after cleaning i refilled and open the bleeder and waited since nothing was comming out i used a little rubber hand pump thats like a straw till the oil came out then tryed to bleed like usual but cant build pressure
If you continue to bleed the way you are you will eventually get pressure just might take quite a bit of time and fluid...
| Quote:
______________________________________
04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit! 92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP 99 BUSA, SOON TO SEE THE ROAD AGAIN |
Good job guys!! talk about online tech support!! I also learned something today. ______________________________________
***SPORTVUE Champion Team Member *** http://www.sportvue.com/ |
I hope you did not put oil into your clutch master cylinder because it take brake fluid. If oyu did put oil into the master cylinder it will damage the seals, what I would do if oil is in the master cylinder is flush with new brake fluid and hope it gets better if not you will have to replace evry thing that is rubber, that means master cylinder, hoses and slave unit. Best of luck to you bro.
68 chevelle 8.95@156mph 02 Busa, Akrapovic race exhaust,Bmc filter,Air box mod,PcIII,Pair mod, -1 in front |
| Quote:
| Quote:
Feb 06 LE 39,381 stock miles. If only the passing lane had a passing lane. |
I could of helped you by the way, if I had checked online. *I just got back from Montreal. *I did see a black/silver busa on Monday or Tuesday around 7pm going down St. Catherine with another bike. *The busa had stock cans with the rear fender chopped off. Was that you by any chance? <!--EDIT|Big E Reason for Edit: None given...|1145512504 --> |
| Quote:
cant wait to go on st cathrine tho!! |
| Thread Tools | |
| Display Modes | |
