Just installed a muzzy system and the oil line on the clutch side needed to be bent ( was hitting header) and the other side has clearance, about 1/16 to 1/8" on both sides. is this ok? I can space out the bottom bracket to gain an extra 1/16 if its worth it.
Deffinately get it away from your exhaust. I didnt and it wore a hole in my oil line. I met some friends at Wheelers after a hard run back from the Dragon and when I put my stand down noticed oil spraying all over the place. Fortunatly, Wheeler hooked me up. Disassembled my shid and welded it then put it back together for 40 bucks....what a great guy.
