I know a guy selling an 04' w/ full RS-3 Yoshi 4:1 exhaust but says he doesn't have a PC or re-mapping? He says it runs and idles smoothly. Are mapping and PC 2 diff things?Yes, or you migh actually lose some performance.
Get a PCIIIUSB and a good map and it will be a World of difference...
David
Yes and No.... Power commander is used to trick your ECU into thinking its see something different than it is. A map is the programing the PC/ECU uses to change the Fuel/air curve, etc... So, the answer to your question IMOP would be to add aftermarket air cleaner and yes buy a PCIII! Then get a map.I know a guy selling an 04' w/ full RS-3 Yoshi 4:1 exhaust but says he doesn't have a PC or re-mapping? He says it runs and idles smoothly. Are mapping and PC 2 diff things?Yes, or you migh actually lose some performance.
David
Should I be concerned and should my first step be to purchase and install a PCIIIUSB? Would help to know in my negotiation$. Is it something I should be able to install myself?
the bike will still run fine without the new map on just exhaust, but with a map and the exhuast it will run even better. you need a pciii to put a map into to, i dont know if you can just load a new map into the bike or not. pciii is well worth the money, you could get one with a map from johnnycheese for a good price.I know a guy selling an 04' w/ full RS-3 Yoshi 4:1 exhaust but says he doesn't have a PC or re-mapping? He says it runs and idles smoothly. Are mapping and PC 2 diff things?Yes, or you migh actually lose some performance.
David
Thanks Sage...looks that way. Wonder why he didn't want the full potential of utilizing full exhuast?So, I think what we are saying is that it is not necessary, but it is a prefered mod when you change out the exhaust system
Aftermarket air cleaner...forgive me but could someone please elaborate? Do you mean a new K&N air filter for example?Yes and No.... Power commander is used to trick your ECU into thinking its see something different than it is. A map is the programing the PC/ECU uses to change the Fuel/air curve, etc... So, the answer to your question IMOP would be to add aftermarket air cleaner and yes buy a PCIII! Then get a map.I know a guy selling an 04' w/ full RS-3 Yoshi 4:1 exhaust but says he doesn't have a PC or re-mapping? He says it runs and idles smoothly. Are mapping and PC 2 diff things?Yes, or you migh actually lose some performance.
David
i am installing a exhaust as we speak, ripped everything apart tonight. does the tps have to be set for the new exhaust? how do you do it?Got my exhaust (Akrapovic Evo) on this weekend (and took off PAIR). Brought the laptop out and plugged it in. When I started the bike it ran ok with power commander using stock map. I calibrated TPS then loaded the correct map, HUGE difference. Leaned it out and throttle response was MUCH better.
So basically yea it will work without a map, but load the map and you will notice the difference immediately.
