micronp450
I wanna say that I've noticed this problem starting ever since I switched to Amsoil a while after I bought the bike used when i finally did change the oil. I bought the bike used with about 5k miles which now has close to 9k.
The problem...
On regular cruising if I upshift to 2nd using mild-medium pressure instead of it clicking right into gear like all other gears it will most of the time "slip" and I will hear a lot clicking lol before it goes in and if it doesn't go in then it will be more prone to going into nuetral. It sounds real bad when it happens almost like its missing teeth off a gear.. If I go higher in the RPM's it seems to get worse and more prone to going into nuetral.. ugh.. Otherwise the bike runs great and goes 140+mph in the 1/4. If anyone needs anymore details that may help please let me know. Feel free to think out loud here.
Thanks a lot...
The problem...
Thanks a lot...
