Had a request for pics of a 200 rear mounted. Keep in mind that the clearance between the 200 and stock chain is very close. I just had the EK ZVX chain mounted and found out the EK chain is about 1 1/2 MM. wider than the stock chain. The tire actually touched the chain in one spot where the tire was wider (Its still new) than the rest. I ground about a 100th of an inch off of about an 1 1/2 inches of the side wall and everything is good to go; no more rubbing. The clearance is tight, but OK.
