I'd recommend the Maxima 15w-50 for where you live . It's a really light 50wt compared to most all others and the antimony is great for the gear set and bearings . Big time phosforus as well . It's used in the Formula 1 oils that I have seen , antimony that is .
Those are nice , modern , 4 cycle engine gasoline engine oils and the Repsol's add pack is not bad at all .
Sorry , did not answer your question . You need the 4T
<!--EDIT|mountainmotor
Reason for Edit: None given...|1142456147 -->
