| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
It won't fit. Even if you get the wheel between the factory arm forks, the tire will rub up front. That is why the wide tire arms are all goofey looking because if you look at it from behind, they had to do a lot of modifications to even get the rim in the arm and have it fit. ______________________________________ CLICK HERE--> *Got-Busa's LSR Project bike* ![]() "TEXAS MILE - 3/28/09: 204.468MPH" All thanks to Brock's Performance and Johnny Cheese Tuned! |
... simple tape measure math here... it ain't gonna fit in the given width.. plus it's stupid looking, and pointless... why you think they put em' on cruisers? they aren't going anywhere, or turning fast anyway. ______________________________________
The edge....I've reached it.
man grumpy -- still with the wide tire thing eh I went as high as a 210 on my rsw but found I like the 200 better. ______________________________________
Blata blatat poot poot pOOOoot <a href="http://www.wunderground.com/US/LA/Metairie.html?bannertypeclick=big2"> |
If you have a good welder he can build a stock arm wide enough to accept any wheel but you will need spacers and it will look weirder than the trac arm.Do it right don't compromise your safety.
______________________________________ Getting You The Right Stuff The First Time To Keep You Riding Longer ![]() www.cloudninemotorsports.com cloudninemotorsports@comcast.net |
I seen a 210 on one and it looked real nice. Bottom line is if you do a wide tire kit you have to go with a jackshaft setup or the wheel will be off center and look goofy ass hell to me
66 inch ,1397 Built by E3performance.com Head and cams by Spaz and carpenter racing Big thanks to Cloudninemotorsports.com *AKA(Goldenchild) |
I don't have a problem with the Trac Arm, if it is kept short. I just wanted to retain the stock look with a little more tire under there. Maybe I'll just save the cash and buy a set of aftermarket rims rim and slug a 200 in there... It just looks sooooo skinny to me after having the 280... ______________________________________ |
ya I know where your coming from -- I take a second glance when I pull up to the house cause I dont see my 200 there in the garage. Then again the first time I headed into a corner at speed on the busa I instinctively braked and countersteered like I was on the Warrior and damn near ran off the road on the inside of the corner (a blip of the throttle remedied that quick tho ) . Will a 200 fit on the Busa in stock trim? ______________________________________
My son put a 200 on the stock rim and it fit fine.
05 RED/BLACK It's almost totally stock, honest! THANK YOU ORG MEMBERS FOR YOUR SUPPORT AFTER MY ACCIDENT, YOU ARE THE BEST! |
200 is about the max unless you trim the chain guard then you have to watch clearance on the chain. <!--EDIT|GoldenChild Reason for Edit: None given...|1130725790 --> ______________________________________ Getting You The Right Stuff The First Time To Keep You Riding Longer ![]() www.cloudninemotorsports.com cloudninemotorsports@comcast.net |
| Thread Tools | |
| Display Modes | |
