+1EK530ZVX
More then good enough with 320hp. EK zvx is about 10,800- 11,000lbs pull.Ive heard the ZVX is more than good enough for a stock Busa.
All chain will stretch, if it did not it would break. They do not over stretch and you should et some good miles out of it. All top of the line chain for each manufacture is good.so did it strech on the break in like ek says with little strech or did it strech alot.
Probably going to have to get the 120 and break it to 112 for stock sprockets.cool thanks for the help one last question the chain comes in 110 links and 120 which one do i get?
does your bike have silver in it. and did you order the 120 and take links out.<- got 1 ... I went with silver..
