What Octane Gas
Rexarmy
This may be a stupid question but. What octane gas do you use?
87
89
93
<!--EDIT|Rexarmy
Reason for Edit: None given...|1117466772 -->
Man this must be a stupid question
87-89...mostly 89. There is no need to run anything higher unless you are running high compression or suffering from detonation problems.
I used to use Sunoco 94 octane with some Cam2. Then again it was in my GSXR750 with the heads done and a piston kit.
