Undertail exhaust
Big E
Well after looking at the pics that Bullet train posted a few weeks back.  It gave me somewhat of an idea on what I wanted to do.  Here are a few shots of the progress.
<!--EDIT|Big E
Reason for Edit: None given...|1115396661 -->
here is the can installed.
<!--EDIT|Big E
Reason for Edit: None given...|1115393927 -->
Still a work in progress. After everything was said and done with. We had some issues with clearance as the rear tire is rubbing against the can if I were to hit a bump. Should be done first thing in the morning. Ill post more pics. Came out fairing well. Thing sounds mean. Basically a D&D can on steriods. Dont know if that is a good thing or a bad thing.
THAT is pretty cool....Wasn't so sure about how it was going to look until the last pic, and I LKE IT!!!
very inovative... looks close to what MH did a while back. He shaped the outlet to fit an entire stock tail light opening.
anticipating seeing the finished product as well! If I like it I may decide to copy you (with your blessing of course)
You may want to fuzz out your plate #s for those less than honest lurkers though
<!--EDIT|MoosesBusa
Reason for Edit: None given...|1115389805 -->
