So, what have you done for your Garage Queen L8ly...............
A very simple to do mod. Get a spare key cut, place the flat side head of the key on the bottom side of the MC
or object you would like to use and mark off the outside area of the key with a pen. This will give you a visual outline of the area that needs to be removed from the key porting that is held between and needs to be dug on the object using a dremel tool with a round router bit attachment. Just keep working the router into the bottomside of the MC until you can fit the entire head of the key inside. Next mix together some JB weld with a tooth pic and shoveled it in the hole (bottom side of the MC) with the same tooth pic. Next, insert the key and let it dry.
Voila, that's all folks
