unfuquitable
Is the piece that broke off in 1 piece?
You asked if it was repairable. You would need the piece that broke off and a real good welder to weld it up.
Then it would need to be smoothed out especially on the inside. So It might be repairable.
However looking at the images you posted I doubt it and you need a new case.
Sorry for your loss.
Engine case ?
Do you have the tools and know how to tear down the engine.
No insurance?
A new/used engine MIGHT be a lot less work - just replace it vs. tearing down what you have. JMHO.
Either way it's going to be $$$$.
Depends on what type of aluminum its made from, some types cant be welded, you may be better off getting a used engine and parting this one and getting some of your money back.
+1, the case is cast aluminum. Good luck welding that.
