cosmic_ocean
There is some play/shake in the drive sprocket when the chain is held and shaken [above the swing arm]. Bike has clocked 11500 odd miles. Is some degree of shake normal or should the sprocket cover be removed and the matter investigated? Can it be a loose sprocket securing nut or some degree of relative motion [between the drive shaft & sprocket] due to normal wear? Also, how long does the gearbox drive shaft bearing behind the sprocket ideally last?
