reusing grip warmers
Redline337
Hey! I'm going to install helibars on my bike and I'm wondering if anyone has reused their grip warmers? If so, is the factory adhesive going to work after being removed from my bar? If no, will grip adhesive work? Would it be easier just to buy new warmers and install one on the clutch side? Any input is appreciated! Thanks!
if you have the adhesive type warmers that wrap around the bars itself then i would buy a new set since they are short money. if you have actual grips like "Oxford", than go for it. by the way, i have those and they heat up much better than the "tape" type. make sure you use a high temp. adhesive to secure them so they don't slip around when you warm those mitts. i made that mistake years ago and the throttle side scared the crap out of me.:beerchug:
