Hey everybody, I've been thinking about doing the switchback change for a couple of years now. I put the 3 wire sockets in the front last summer and ran "normal bulbs" and everything has worked out fine so far and want to make the swap to switchback's now while there is still snow on the ground
For any of you that have installed these, can you offer any feedback on these three questions?
What is the largest bulb that will fit in a Gen 1 without any issues? I can see there are 48, 60, 96 120 LED towers and a bunch more... I am looking here:
Home of the Original Switchback Led Bulbs for Turn Signals | Autolumination
Did you have any problems if you bought the bulb that blinks amber, but returns to white in between blinks? (As opposed to amber on and off with no white until the blinker is turned off)
Finally, is the relay mod necessary or can you buy an LED flasher? I remember reading a thread somewhere that said you can buy an EP-35 LED flasher replay and it is a plug and play replacement.
Any advice you can all give would be much appreciated.
