hayabusa07
I have an 07 hayabusa and it's about time to adjust the valves. While my tech is doing that I figured I'd upgrade the cams since they are right there. I was told you can take some adjustable cam sprockets and put the intake cam on the exhaust side and gain a couple extra ponyes. Then on top of that put an new stage one upgraded cam on the intake side then degree and dyno tune them. Hotcam offers a stage one intake cam that you can use stock valve springs with. But unfortunately they are still in production. My question is does anyone have a recommendation on a upgraded intake cam I can use with stock valve springs? And any in put on me putting the intake cam on the exhaust side while upgrading the intake side would be appreciated.
