i ran into reliability/durability issues with the brake setup on my buell 1125r. enough to make me want to , and eventually get rid of the bike. they were supposed to be floating but the design doesn't compare to the hub mount floating rotors. the heat transfer was reduced due to the small contact areas over such a large wheel, they got really hot real quick. 5000 miles on a new rotor and it was warped ... hold the brake lever down at a stop light on a hot brake and the pad starts to melt onto the rotor.. enough of those causes enough buildup to make the lever pulse. Lots of people were regularly cleaning rotors with brake cleaner and scotchbrite. I didn't enjoy the maintenance of that setup... plus the rotors weren't cheap or readily available.
Obviously Buell got it wrong on that bike. On my set up , they are true full floating rotors and you can feel the rotor move slightly upon brake application. With 2 front rotors, they are formidable brakes. Mine use 4 piston calipers, not 6.
I have put on 10000 miles on mine since I got the bike and they hardly show much wear.
I will have to buy a different master cylinder at some point as they are too strong.
They dont use steel brakes for racing, they use carbon brakes. Steel are too heavy for race use...
BB
