hey guys i just installed the 1" risers and it was a breeze. now how do i pull the forks up and how much? i have a rear stand and a front stand that the "pegs" sit under and behind the forks. pleze help
Lossen the clamps slowly and let em slide through till the stop at the top tree. You can usually loosen 3 of the 4 total clamps and then use the 4th to control the slide.
Even with the bolts backed out it takes a bit of effort to knock them up or down...it may help to use a sharpe marker / tape to show the left / right fork tube change...just to keep them the same...if you have a digi caliper or gage that will also prove the l/r being equal
