Disable Ignition for Battery Load test
LiBusa
My battery would not start my bike after a local ride. I have done several battery/charging tests per the factory manual which shows that the charging system appears OK. I want to do a battery load test on my Busa. Is there a fuse or wire(s) I can easily unplug/replug in order to crank engine for about 4-5 seconds without engine starting.
Regards,
Lionel
I remove my battery and take to a local auto parts store who performs load-testing for free. If not feasible for you, maybe this DIY can help (NOT FOR A BUSA but should give you an idea): How to Load Test Your Battery
