2008 hayabusa
TUNA
Hello,
Can someone help me with maybe a silly ? I have an 08 Hayabusa and I just started having this problem,on initial startup i pull the clutch in and put it in 1st gear and it jump's forward,then when im riding and come to a stop i pull clutch in and it doesnt disenguage rite away , now is there some kinda adjustment at all that i can do for this to stop happening? fluid is full !! any ideas would be much appreciated, thank you in advance!
TUNA
Check to make sure the front sprocket cover is not cracked. Look at it while pulling in the clutch and see if the clutch slave cyl. moves.
Did you change anything on the bike since you noticed the problem? Levers? Fluids?
