superspeedy
Woolich Racing interface and ECU editor issues
I bought a WoolichRacing tuning logbox, We have tried to flash Gen II Busa ECU today, but there has been couple of issues. It seems that the interface is not working.
I thought there might be something wrong during flashing ECU. Then I took everything off from the bike. But the bike could not be started, and the FI light is flashing.And there are many DTCs that the shoftware showed. The most wierd thing is the TPS is almost 100%.
And the status light of tuning interface is flashing sometime once I connect interface to laptop.
Is the "LF" of th switch is ECU data mode, and the other side is flashing mode right?
I followed the process as below:
1. got all wires connected
2. put the switch to "LF" and connected the interface to laptop
3. open a stock map as Hayabusa K8
4. made changes in fuel map and limiter, set softcut at 12000rpm and add abit more fuel at higher than 11300 rpm
5. put the switch to another side
6. flash ECU
But there was a error note come up when I tried to flash, verify checksum and veryfy/read, it said: Unexpected or missing ECU response during initialization. Verify aborted, reset ecu and retry.1 0. And sometime error note is:unexpected or missing ECU response durig initialization. Programming aborted, reset ECU and reprogram.0 0
The most wierd thing is that the bike can not be started at all even I got all wires disconnected from ECU.
This is my first to flash stock ECU. Anyone can instruct me a proper procedure of using ECU editor to flash stock ECU?
Thank you so much!!!!
6. flash ECU
