Results 1 to 15 of 15
  1. #1
    Hayabusa Immortal
    Pipefighter248's Avatar
    Join Date
    Feb 2004
    Location
    Ashland, KY
    Posts
    12,501
    Default Quick easy question
    Messing around on the bike and have a question.
    Does the throttle cables go on the inside of the front brake lines or does it go around the outside?
    Where they cross, is the throttle lines or brake lines closet to the rider?
    Thanks.
  2. #2
    Suffers from PBSD
    Blanca Busa's Avatar
    Join Date
    Oct 2009
    Location
    South Florida
    Posts
    20,137
    Default Re: Quick easy question
    What yr bike? I can snap a pic or two for you if you want.
  3. #3
    Hayabusa Immortal
    Join Date
    Feb 2004
    Location
    Ashland, KY
    Posts
    12,501
    2003
    Thank you.
  4. #4
    Suffers from PBSD
    Join Date
    Oct 2009
    Location
    South Florida
    Posts
    20,137
    I've got an 09. But if it's same what area you need a pic of?
  5. #5
    Hayabusa Immortal
    Join Date
    Feb 2004
    Location
    Ashland, KY
    Posts
    12,501
    Trying to find out if the brake line off the front master cylinder goes down on the inside of the throttle cables loop or on the outside.
    Probably doesn't matter, but just want to make sure one or the other isn't in a bind.
  6. #6
    Suffers from PBSD
    Join Date
    Oct 2009
    Location
    South Florida
    Posts
    20,137
    Does this help?
    On a genII it seems the brake line is in front and routes in front of throttle cable.
  7. #7
    Suffers from PBSD
    Join Date
    Oct 2009
    Location
    South Florida
    Posts
    20,137
    Oh wait a minute both those are throttle cables
  8. #8
    Suffers from PBSD
    Join Date
    Oct 2009
    Location
    South Florida
    Posts
    20,137
    Brake line is in front of both those on mine.
  9. #9
    Hayabusa Immortal
    Join Date
    Feb 2004
    Location
    Ashland, KY
    Posts
    12,501
    Would be perfect if you could take a pic of the same area from the front looking back.
    Looking for brake line out of master cylinder.
    Appreciate the help as always.
  10. #10
    Hayabusa Immortal
    Join Date
    Feb 2004
    Location
    Ashland, KY
    Posts
    12,501
    Second pic is perfect.
    Thank you sir. I appreciate it.
  11. #11
    Suffers from PBSD
    Join Date
    Oct 2009
    Location
    South Florida
    Posts
    20,137
  12. #12
    Suffers from PBSD
    Join Date
    Oct 2009
    Location
    South Florida
    Posts
    20,137
    I had my lines changed to HEL and from looking at it it looks as if it would be straighter if in front?
    I am now wondering if it is in front when new and still stock?
  13. #13
    Poppy's Avatar
    Join Date
    Aug 2005
    Location
    Relocated out west
    Posts
    3,597
    fyi.....I checked my '02 and the brake lines (SS) hang straight down and the two throttle cables curve towards the back, on the outside of the brake lines.
  14. #14
    Poppy's Avatar
    Join Date
    Aug 2005
    Location
    Relocated out west
    Posts
    3,597
  15. #15
    Hayabusa Immortal
    Join Date
    Feb 2004
    Location
    Ashland, KY
    Posts
    12,501
    Thanks Poppy.
    Have the same setup. Was messing around and couldn't remember which way it went.
    Thanks.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
