Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By Busa1166
  • 1 Post By lankeeyankee
  • 1 Post By captain
  • 1 Post By semi
Thread: Tire Pressure Monitors
  1. #1
    I made fun of the panties, now I have them :(
    Join Date
    Apr 2010
    Location
    N/A
    Posts
    2,481
    Default Tire Pressure Monitors
    I was wondering is using valve mounted TPMS sensor on an angled valve stem would be a problem? I have been told that the weight of the sensor/battery caap can damage rubber valve stems, but do you think that would be an issue with billet valve stems that are angled?
    I ordered the TPMS from Pashnit.
    In case you were wondering, yes I am too lazy to just check the pressure. Actually I wanted to be able to see fluctuations in the pressure more so than cold pressures.
    I've used 9 of my 9 lives so far!
  2. #2
    Hayabusa Immortal
    Asteroids Champion Busa1166's Avatar
    Join Date
    Jul 2008
    Location
    Miami, Fl
    Posts
    8,898
    Default Re: Tire Pressure Monitors
    You can mount the tpms on the top and then just uncap and fill the tire without ever messing with your sensor. I don't know if Pashnit sells these valve stems but Hawkshead does
    They may not be to pleasing to the eye but the functionality seems well worth it
    fallenarch likes this.
    Name is Manny
  3. #3
    Hayabusa Immortal
    lankeeyankee's Avatar
    Join Date
    May 2011
    Location
    Pleasant View Tennessee
    Posts
    3,309
    I would be concerned also with the extra weight and making the tires out of balance. I personally would wait till its tire replacement time. Order some good qaulity metal valve stems install all your neat guy gatchets on and then have them balance the tire if you want it done right.
    sixpack577 likes this.
  4. #4
    Join Date
    Apr 2010
    Location
    N/A
    Posts
    2,481
    I already have billet valve stems. Supposedly the sensor is light enough to not require balancing. I guess I'll let you all know when it gets here.
  5. #5
    Dis in my way!
    captain's Avatar
    Join Date
    Nov 2001
    Location
    Oklahoma
    Posts
    16,299
    Uncle Steve put his on the outside with 90 degree and never had a problem.. I have my TPS on the inside of the tire..
    Good citizens know they're accountable for their actions (someone has said, "My right to swing my arm ends when my fist hits your nose").
    "Words can hurt. Words can heal. Therefore it is of the utmost importance that we pay attention to our words."
    On the Internet in some quarters, freedom is being abused and used irresponsibly as a smoke screen to communicate in a vulgar, profane, violent, and insulting manner.
    "Freedom requires that at the end of the day, we accept the constraint that is required...."
  6. #6
    Whoooosh!
    semi's Avatar
    Join Date
    May 2006
    Location
    next door to Alice
    Posts
    16,168
    i've been using them for several years without any problems (they have saved my rear end twice!)...just don't run them on rubber stems
    People with courage and character always seem sinister to the rest. Hermann Hesse
    A man must be both stupid and uncharitable who believes there is no virtue or truth but on his own side. Joseph Addison
    Count it the greatest sin to prefer life to honor, and for the sake of living to lose what makes life worth living. Juvenal
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
