1styearbusa Registered Jul 18, 2012 #2 I am rather certain they are cast aluminum , like almost all stock wheels that are not cruiser-spoke type wheels .
T Trout Registered Jul 18, 2012 #3 Fun exercise... I came to the same conclusion (cast aluminum) by process of elimination: You can't make a 1 piece wheel from spun aluminum. Machined aluminum would be very cost prohibitive for an OEM part. Cast iron wheels would weigh 50 lbs each... like spooning tires on a pair of dutch ovens. Stamped steel and welded (or riveted) wheels are so... 1970's. Yep... cast aluminum. Is anyone else bored at work today?
Professor Hayabusa Immortal Staff member Administrator Registered Jul 18, 2012 #4 1styearbusa said: I am rather certain they are cast aluminum , like almost all stock wheels that are not cruiser-spoke type wheels . Click to expand... That is correct!
R RX1Jim Registered Jul 20, 2012 #5 Why do you ask? Do you need to repair one or are you tinking of plating or painting one?
