Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 88
Like Tree16Likes
Thread: My experience with my POS Hayabusa
  1. #41
    Hayabusa Legend
    jellyrug's Avatar
    Join Date
    Oct 2008
    Location
    Pinehurst NC
    Posts
    2,319
    Default Re: My experience with my POS Hayabusa
    When I hear these horror stories, it makes me realize how fortunate we are, who understands all the technicalities and are able to take care of our machines, our own services and repairs.
    A Busa is a fine piece of technology, but it is not simple technology and under the wrong hands I guess anyting goes.
    Busa K9 Silver
    Husqvarna TE610ie 08
    Harley Dyna Superglide 2010
    GSXR600 K7
    Always ride as if everyone is trying to kill you, ... as they are.
  2. #42
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    11,932
    Ok there is one bolt on the oil pan that is supposed to have a sealing washer, it of the very back corner of the oil pan, directly under the clutch!
    04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit!
    92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP
    99 BUSA, SOON TO SEE THE ROAD AGAIN
  3. #43
    In the second (middle) picture you can see part of the oil pan. You can't see the whole pan but I checked it out and the leak is not coming from the pan. It is clean. The bolt surrounded in pink is the bolt where I think the oil is leaking from. In order to see it clearly, you would need to take the lower fairing cowl off and then crawl under the bike with the top of your head touching the front of the rear tire.
  4. #44
    Hayabusa Master
    #1busa's Avatar
    Join Date
    Sep 2011
    Location
    east coast
    Posts
    1,620
    I would wait to spend a ton of money on this bike untill you get it back up and running (healthy) for an extended period of time...........the curse that was placed on your busa may or may not be lifted.
  5. #45
    Quote Originally Posted by #1busa View Post
    yeah ya think...
  6. #46
    Top Gun
    Join Date
    Mar 2009
    Location
    Pinellas Park FL
    Posts
    1,229
    That little bit of oil would not worry me. It is so little your not 100% sure of where the oil came from. This motor you can just ride and not have to worry about it. Also leave the PC3 off of it. A slip on and filter is all you need. It will run forever. The old motor that you have in storage is a parts mule for the current motor in the bike! Good Luck and ride the heck out of it.
  7. #47
    Rookie
    Join Date
    Apr 2012
    Posts
    296
    x2 on leaving the pc3 tune off OR getting it retuned....you did say you went thru 2 cylinder heads so that might be something to look into...maybe a bad tune
  8. #48
    Quote Originally Posted by Spkrdctr View Post
    Yeah I agree. It doesn't worry me either when I am riding it in the sense that I feel it is dangerous. It's not spraying out by any means so it's not going to compromise the tires. But it just bugs me because I was hoping to have it back to 100%. The leak has became even less since I first noticed it after the guy put the motor in. It does run great though. It's real strong and sounds just fine. I have already come to the conclusion that I am not putting any more money into it as far as mods or whatever besides regular maintenance. The bike is what it is now. I always tried to care for it the best I could. Here is a pic:
    Attached Images Attached Images
  9. #49
    Quote Originally Posted by superchargedv8 View Post
    There was not pc or K&N on the bike when the first head went. I don't even know if I had the slip-ons...can't remember. This last time it had the pc w/ tune, slip ons, & filter. The A/F graph didn't look to bad. I actually had it checked by another mechanic after the tune was done. I don't know. Maybe I'll take it off.
  10. #50
    just for clarification, i don't know what was wrong exactly with the old motor this time. It is either the head gasket or the cylinder head cracked again. Either way, there was no reason for either to occur.
  11. #51
    Enjoying 1 road at a time
    raydog's Avatar
    Join Date
    Sep 2006
    Location
    Reno, Nevada
    Posts
    4,341
    Sorry, I did not read this entire thread, just your opening scenario...Without going into my experiences too much here, I can say that if you get a consumer affairs specialist attorney, you will win a case that will never get filed in a civil court. I fought a "refusal to cover" case with Nissan re: my twin turbo 300zx throwing a rod....and won it all (when Nissan corporate got my attorney's letterhead letter, they called him and offered 12K, I countered with 18k and settled at 16k). This is common....they resist till the last moment then write a check (atty takes small amount of payoff, make sure you add that to your demands). DO IT! BTW, don't blame Suzuki, ALL corporations and their networks ARE THE SAME. I don't care if it's GM or freeking Bugati. Since that issue eleven years ago, I've owned 2 more Nissans (after I stopped hating them). Raydog
    2000 HayBus..track bike, sport touring. Full Race Tech Suspension, PC III, Corbin, Sato rearsets, Matris damper, carbon fender, Carbon Muzzy, HID lighting, billet countershaft cover, Woodcraft, Pazzos, 0-6" arm, full Autocomm electronics, Heli, Beltronics, Zumo, etc.
    2005 Busa naked Superbyke..Accossato radial brake master cylinder, Steigler superbike handlebar conversion, Race Tech springs, Matris damper, Pazzos, Carrozzeria wheels, Braking rotors, Tobin, Oberon barend mirrors, M-4 exhaust, carbon fender, Hotbodies tail, Kellerman turnsignals, much more, still under construction.
  12. #52
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    11,932
    If it is directly under the rear bottom corner of the clutch cover, it needs a sealing washer! Here is the part number,,09168-06023.
    It costs a $1.50!
    Quote Originally Posted by Busa Phil View Post
  13. #53
    Top Gun
    Join Date
    Mar 2009
    Location
    Pinellas Park FL
    Posts
    1,229
    I'm glad you just riding the bike now. I think they are a lot more fun when ridden WITHOUT putting moneyh into them. I left mine stock except for comfort mods (raised handlebars). They run strong and last forever. People have to mod stuff and then they come on these boards with problems. Anyway, seems like your all set now. Good Luck and have fun. A nice looking bike. I too would have gotten an attroney and went after Suzuki plus my attorney costs. But, riding is more fun! Good Luck!
  14. #54
    raydog's Avatar
    Join Date
    Sep 2006
    Location
    Reno, Nevada
    Posts
    4,341
    Your opinion of folks aftermarketing their Busas may apply to some without either aptitude nor desire....but don't indict an entire subculture of Busa owners that are in heaven enjoying their IMPROVED upon Hayabusas. It's simply not accurate and a gross generalization. Raydog
    jefro likes this.
  15. #55
    Quote Originally Posted by GIXERHP View Post
    It costs a $1.50!
    I will check the location of the bolt again as soon as possible and install a new washer.
  16. #56
    Join Date
    Mar 2012
    Location
    Hell, Indiana
    Posts
    21
    Default
    Pictures from the lowest point to highest point. I am 99% sure that little bolt is the culprit. It's kind of weird to me that it would spring a leak there though. Is it safe for me to back it out and put some sealant on it and put it back in? Or is going to start pouring oil out of there when its removed or worse screw something up internally?
    NM... didn't read rest of thread before speaking out about gasket washer
  17. #57
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    11,932
    Well time will time in the am, i now have a bad motor in my garage!
    I will start the tear down in the am!
  18. #58
    Poppy's Avatar
    Join Date
    Aug 2005
    Location
    Relocated out west
    Posts
    3,597
    Hopefully everything is worked out, besides the small dribble.
  19. #59
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    11,932
    Yes the original motor!
    Quote Originally Posted by Poppy View Post
  20. #60
    Poppy's Avatar
    Join Date
    Aug 2005
    Location
    Relocated out west
    Posts
    3,597
    haha! I edited my post....probably after you quoted it....
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
