Aftermarket headlight bulbs
RX1Jim
Has anyone installed aftermarket headlight bulbs and found they are worth the money: brightness, visibility? I am thinking of installing a pair of Sylvania UltraStar bulbs in my 09 Busa. They are a pain to install so I wanted to check in before buying them and taking teh front end plastics apart. Thanks!!
They are not that bad to install. 10 minutes to pull the plastics off the panel and remove the cluster. And since you're doing that, might as well throw some HID's in there instead of aftermarket bulbs. Heck, DDM tuning HIDs are barely more than good Halogens, and you will not regret it.
