Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2012
    Posts
    Default 05 Hayabusa 1300R
    Just trying to get some ideals of where to start troubleshooting my 05 Busa. I was riding the other morning and it just made a noise and started shutting down while was still riding. I pulled over and it turned itself off. I started it back up with some effort but it sounded like a Harley and ran for little bit but shut off again. I towed it to the house and tried to start it but won't even turn over. I charged battery but when tried to start it up it just clicked and all lights went out until I took hand off start button. I'm starting with the battery and starter but needed to see if anybody had same problems with theirs or anything else might need to check.
  2. #2
    Professional Pilot
    Join Date
    Feb 2011
    Location
    CA
    Posts
    974
    Default
    You shouldn't be running off the battery while riding. And the starter would not have killed the bike. If you get a new battery make sure you check that the stator is charging.
    Kinda answering just to keep this bumped.
  3. #3
    D' Colonel
    DaCol.'s Avatar
    Join Date
    Nov 2005
    Location
    Oklahoma
    Posts
    7,722
    Default Re: 05 Hayabusa 1300R
    By saying it sounded like a Harley, do you mean it sounded like is was only firing on 2 cyl ?? If so have you checked your fault codes, kinda sounds like electrical or fuel injection problems. But without the trouble code, your just guessing
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
