if key switch will turn with a flat head screwdriver even if damaged, hook the wires color for color and should power up. the ignition switch has an immobilizer in it. if you don't put a resistor in line of the wires it won't crank without going thru the switch..
Well they completely destroyed the tumbler so I will have to buy a new or used one to see if the bike will run. I highly doubt they got her started, but still amazes me how they damaged every panel on the bike.
