Intake cam swap? Putting an intake cam in the for the exhaust.
Just bought a new 06 Busa & was told it had an intake, intake swap conversion. Can someone enlighten me on what this means? Thank You.
Its about the ride
but you have to degree the cams...not just swap it out.![]()
"In God We Trust"
"Lifes tragedy is we get old too soon and wise too late"
177.4 TX Mile March 2011
189.7 TX Mile Oct 2011
199.0 TX Mile March 2012
210.5 TX Mile Oct 2012
210.8 TX Mile MArch 2013
Yes, the cams were degreed I'm told. All of this is over my head right now. I'm only CURRENTLY fluent in 2-stroke world. What benefit is this mod to my Busa? Guess I just dont understand the significance.
One of the most popular Busa modifications is to swap out the stock exhaust cam for a stock intake. The intake cam has a higher lift profile than the exhaust for more flow and power. The main problem encountered when doing this mod is that the intake cam sprocket has to be installed in a different "index" for the exhaust cam. APE solves this problem by supplying these cams with our adjustable cam sprockets indexed for use on the exhaust.
These are brand new factory Suzuki cams, with new bearing and APE adjustable sprocket. Ready to install. Works with stock valve springs. Direct bolt-in.
Do you have a intake cam only for sale .
Bill
Texas march 09 199.166 Texas oct 09 199.780
Loring aug 09 207.837 , Mojave 2010 186.8
Texas march 202.3 2010
Loring 2011 208.487
Texas 2011 204.9
Moved for housekeeping.
IBA #39091
