RedBusarider
I have searched and searched and have not found an answer.
What I want to know is HAS ANYONE GOT THE ROSTRA CRUISE CONTROL TO WORK PROPERLY ON A GEN I ?
I have had mine on for a while and not gotten the results I wanted.
It will engage, but then slows down, then speeds up, then slows down and then disengages.
If I don't turn on the unit it will make the speedometer jump around. Turn the unit on and the speedometer is fine.
I have tried different settings and none have given me the proper results.
So again has anyone with a Gen I gotten the Rostra cruise control to work properly?
I read that there might be updates to certain units? Can this be true? Do the electronic versions NOT work on the Gen I ?
Do they even still make the vacuum version? I don't really want to change everything out but it doesn't do me a lot of good like it is
in that it won't stay engaged, even on flat and level roads.
ANY help will be appreciated. I really want to ride the Busa more this year and a working cruise would help a lot
