bigjack7679
I come to the wise ones of Hayabusa. Org once again for advice
I have problems with my 08 busa starting sometimes when the engine is real hot. It acts as if the battery is dead, but all the lights still shine bright. I let it sit for 30 mins or so and it starts right up. I cut it off and on 8 times and it started up like a champ. It did it one other time that same day.
Fast foward a week and i stall at a red light . lease: dont judge. when i began to restart, it turned over slow(draging) and i was ready throw a fit but it started up. Once i made it home, i Restarted it 5 times. No problems at all.
I found out from one of my other post about an extended warranty that there was a recall on the rectifier. I searched the org and found that some other members posted on some rectifier threads about this same problem but didn't find an answer to their post. I called the dealer and my bike was on the recall. They should have the part by friday.
Also, the battery is new and is pluged in the tender every night
Can the rectifier be causing this problem?
