I must be sick or somethin.. I was bored and couldve been looking at porn but decided to read the troubleshooting section in the busa manual.. my question is with the fault codes..
How do I get them out of the computer if i need to?
Here is a quote from another post by Rhythm
"Its located on the clutch side of the rear fairing and covered with a rubber cap. Pull the cap off and jump the two sides using a piece of wire any gauge that will fit .
Connect both side as in the photo, then turn the ignition on" and the code will show on the odometer
<!--EDIT|atticdog
Reason for Edit: None given...|1100474258 -->
