Handle bars
willcosta
Hi all,
Just wondering if there is a riser for the handlebars on an 09 so I can sit up a little more and not have so much pressure on my hands. If there such a thing will I need extra long clutch cables, throttle cables and break lines, and where could I buy them. Thanks for any help you can be. WILL
Soupy's makes a nice 1 inch block to raise your bars, Or you can just get the spacers from them. And no you will not need to change anything unless you go over an inch, And then I am not sure what all may have to be changed. Soupy's is a sponsor here.
And :welcome:
Here is a link to the block that they have, It says lowering block but alot of people me included use it for a handle bar riser.
http://www.soupysperformance.com/catalog/item/4408900/6637181.htm
