Medic, it's late and I'm tired but your question has me a little confused. You are running a full Yosh pipe and getting only 30 mpg...or you have just changed to a different pipe and getting different mileage..or you are going to change to another pipe and wondering what will happen to your gas mileage?
I have an 08 Busa and with stock everything was getting anywhere from 45-50 mpg depending on wrist action. Put a full titanium Brocks single sided race pipe on it...new carbon fibre wheels..basically dropped 50-60 lbs off of the bike and now am getting 35-39 mpg. Why? race pipe allows the bike to get more power...also the oem settings are notoriously lean...so when you open things up with an after market air filter...get rid of catalysts, baffles, and pipe allows the after exhaust to flow much freer without constrictions of an oem pipe...you get alot more power...and power means fuel economy goes bye-bye. Ain't the same bike I had before...and with carbon fibre wheels...it is as flickable a bike as a litre bike now. I hope this helped
