rockethead
I have the GIPro ATRE. I have the red wire connected to the red terminal on the battery..
question: is the GIPro ATRE drawing any current while the battery is off??? I heard to wire it to the fuse box but Im not confident enough to mess with the fuses and thought I'd hook it to the battery. I think it's ok because the GIPro doesn't light up while key is off and if I push the button on the bottom nothing happens so am I ok with it hooked to battery or not?
suggestions would be great
