CopMagnet5oh
i got a 99 busa with some weight savings, 33k miles on it, with factory damper ( good condition, i inspected last year ). i had the rear raised 1" and running 180 pilot power rear tire. i like turns and ride aggressively. I am 150lbs + gear, and got +5 rear sprocket. bike made 159rwhp and 97rwqt. had the suspension set by a good rep. shop /pro racer for my weight ( me sitting on the bike, last year )
Short turns/ low speeds are not an issue, but longer turns/higher speeds i can feel the whole bike wobbling, specially when the pavement isnt all that great.
So, my question is: will i benefit by installing the aftermarket steering damper on my bike, or is the problem isnt related to that ? I had two different suspension settings and both resulted in that wobble, i thought maybe my rear settings were adjusted too hard and not giving it enough room/time to respond to the uneven pavement when the bike is leaned over all the way, but thats just a guess. local shops are willing to help to the point where you come back with an issue, then they want nothing to do with you.
thanks guys!
- Kons
thanks guys!
- Kons
