Paint question
Kahunas
I was wondering if anyone has ever painted their pipes before?
My bike is mostly black and my pipes are kinda well they dont look pleasing could i paint with grill paint or a engine high temp or not?
i used semi gloss black engine enamel, made by duplicolor. they also make a grey engine primer that i used underneath. sand it by hand, apply the primer and spray away.
That looks good thanks for info .
i didnt see any posts about from can to engine so thought maybe you guys would know so thanks .:beerchug:
high temp paint has a tendency to flake off eventually..
depending on your setup, jet hot coating may be the best way to go..
all depends though
i've had a positive experience with it so far.. 38k miles and counting..
it's about due for a touch up from a few incidents but the paint has held well.
all depends though
jet hot coating never heard of it il have to search on that one , is this expensive ....im guessing yes???
I have another question im finding in the search ...has anyone ever just re clear thier bike so it will shine mine looks like it could use it or would i need to just repaint the whole bike starting with primer?
thanks in advance.
thanks in advance.
my 2 cents: get the bike detailed, DIY or by a pro (if you lack skill/experience in doing so). cheaper vs reclear/repaint.
