Brew City Busa
i took the frame apart for powder coat and i just removed the lower fork clamp from the frame and tried to remove the lower bearing on the shaft but couldn't. So the question is, is that shaft that goes through the frame pressed into the lower clamp or attatched a different way. I don't want to start pressing it and have it bust so any input is welcome.
Thanks
Thanks
