Do you include regular brake fluid flush/changes in with your normal maintenance intervals~?~
If so, how often~?~
I have a concern about using specialized racing fluids (about $15 a pint), and that is unless I keep the bottle on the shelf it's hard to purchase the same thing each time and a flush is needed since I understand you are not supposed to mix fluids...anyway, what's your input...
If so, how often~?~
