moloko
Banned
I was gonna pick up a set of baffled exhaust tips. I can't find any application specific.
On the '99 / '00 the midpipes have to be cut off, cuz they're welded. Before I do that, does anyone know the inside diameter of the pipe? Or should I go with the outside diameter instead? IE: to fit the tip either inside or over the outside of the pipe.
The pipe has a big seam on the outside going lengthwise so unless I grind it down I didn't think I'd get a very good seal, was prolly gonna go with clamps instead of welding for now... although welding isn't out of the question.
I just didn't want it to be even more of a pain if I wanted to swap it again (being welded) Guess I could find another set of midpipes, but then I just have more crap cluttering up my garage.
