Hello all,
Im posting for a friend with a 2002 busa,,,
all stock..
BUT he decided to put a after market cover on in place of the stock stator cover,, after he buttoned it up it will not start,,
Motor cranks and backfires out the exhaust,,
Questions:
1: He removed the stator and put it inside the aftermarket cover,, is there a crank position sensor or something built into the stator,,,?
2: is there ANYTHING under that cover that can cause a timing issue... that is what appears to be the issue..
He is very dilegent and has sworn there is NO pinched wires or anything and asked me the above questions,,,
I told him i would post but thought thatthe bike would run without the stator even plugged in,,, ??
SO what could be the issue....
Thanks for your
all stock..
Questions:
Thanks for your
