SHIRO HAYABUSA
I have the chance to get a 220mph cluster to replace stock, which is fine but odometer and speedo needle doesn't register. The mileage between stock and 220mph are almost exact. The only problem with the 220 is the left lower screw bracket is broken off. All other tabs and the right screw bracket are intact. What do you guys think?
